TractorLinks.com
Show Parts for Model:
Re: 2840 Rockshaft linkage fulcrum
Tx Jim
08-12-2014 03:30:25
I think the cam(parts key 7) must stuck on the lever(parts key 6) as when adjusting valve clearance one doesn't need to turn screw(parts key 8) much to get a lot of clearance. From your description I think you have the fulcrum installed correctly. Is spring(parts key 9) attached correctly??
Bob Angus
08-12-2014 18:06:39
 Re: 2840 Rockshaft linkage fulcrum in reply to Tx Jim, 08-12-2014 03:30:25
Tx Jim. Maybe the cam is stuck. I get very little increase in neutral range by going 2 turns. However, fully tight(full counterclockwise) the valves are spraying. They stopped after turning out clockwise, so it must be doing something. I cant seem to get the 2-4mm free play spec on the lever. I got maybe 1mm., and I don't want to go more than 2 turns because I am paranoid about the screw backing out, and seems like that's about all the adjustment its got. Does this sound normal? If stuck so any ideas on how to free this up through the plug adjustment hole.Should I be worried about this or is this close enough?
Tx Jim
08-13-2014 03:11:37
 Re: 2840 Rockshaft linkage fulcrum in reply to Bob Angus, 08-12-2014 18:06:39
I think if spraying of the oil stops then you should be fine. Only good way to check linkage is to remove RS housing from tractor.
Bob Angus
08-12-2014 06:53:39
That's a good thought. Like I said, I am pretty sure I have the fulcrum right as it doesn't fit the other way. Spring is definitely attached. I'll get a screwdriver in there today to try to see if it is free. Thanks Tx Jim.
