Plow Update
JD John
Got the wheels off and sand blasted, they are in good shape, not many pits and could read part numbers still. When I was taking the shares off I found something odd, one bottom was wore alot more than the rest and had left handed threads. Share was a different brand also. It was a STAR MFG CO the rest had LH D 14 4 on the back and could see some green paint still. Don't know if they are Deere's or not!
I've never seen a number like that stamped in the wheels.
As for the shares, many aftermarket manufacturers used left hand thread bolts...I think it's a myth, but I've been told left handed threads would hold tighter than right handed; but if you're like me plowing fast enough to create harmonic vibrations strong enough to loosen a bolt isn't a problem.
STAR was an aftermarket plow parts supplier. The other share may be deere, but I can't tell from the picture.
Tyler in IL
