3020 injection pump removal
Does anyone know a better way to get the timing marks lined up on a injection pump for removal than cranking the engine over with the starter? I cant even come close to getting them lined up using this method. Thanks
Pull the injectors first, that will remove the compression. I have pried flywheel with screwdriver in timing hole, also on hydraulic pump coupler.
