piston pin bushings
36 A
Doing a rebuild on a 39 B and need some piston pin bushings . I there anybody making these in the after market or is deere the best place to go ? Thinking over sized pins isn't going to work these things are shot !
Are you reusing the pins? They are probably worn as well as the piston holes.
Sharps might have them. Steiners as well.
Went and took a good look and one is bent and the other the rod is out of round . Ill look for other rods .
