TractorLinks.com
Show Parts for Model:
Re: 4020 3pt doesn't work now after changing the seals an shaft
bryang
08-11-2014 14:14:45
When taking off the valve block is their anything to watch for or keep in mind? Never took the one on the right off before.
Tim S
08-11-2014 14:53:52
 Re: 4020 3pt doesn't work now after changing the seals an shaft in reply to bryang, 08-11-2014 14:14:45
You will need a new gasket,, blow the area clean before you lift it and the hidden bolts should need a 9/16" socket,, but they rust bad down in there so you may need to use a 1/2"..
bryang
08-11-2014 15:24:31
 Re: 4020 3pt doesn't work now after changing the seals an shaft in reply to Tim S, 08-11-2014 14:53:52
I will have to get a gasket for it tomorrow. Cleaned it up good an all the bolts came out fine but it seams to be stuck not wanting to come off from the rear of the tractor. I cant find my book so im kinda relying on your guys for help!! Thanks for everything so far!!
Tim S
08-11-2014 15:53:06
 Re: 4020 3pt doesn't work now after changing the seals an shaft in reply to bryang, 08-11-2014 15:24:31
Make sure you got "all" the bolts out...i think there are 8...
Tx Jim
08-11-2014 16:18:17
 Re: 4020 3pt doesn't work now after changing the seals an sh in reply to Tim S, 08-11-2014 15:53:06
I checked the parts catalog & Tim is correct about eight(8) bolts holding RS valve housing on.
R26573 Gasket - GASKET,ROCKSHAFT VALVE HOUSING ADD 6.33 USD
This post was edited by Tx Jim at 16:18:40 08/11/14.
bryang
08-11-2014 16:51:00
 Re: 4020 3pt doesn't work now after changing the seals an sh in reply to Tx Jim, 08-11-2014 16:18:17
Yep I forgot one bolt got it out an off an yes in deed the little finger on top flipped over. ill get the gasket tomorrow if they have one probably not our local jd dealer has everything but what everyone needs!! THANKS for all the HELP guys I appreciate it!!! Thanks
