TractorLinks.com
Show Parts for Model:
Re: 4020 3pt doesn't work now after changing the seals an shaft
bryang
08-11-2014 13:14:34
Don't know if this matters but the 3pt raise an lower lever was in up/raise position.? I think when i have done others they were in lower. Would this cause a problem? Just a thought!? Looks like ill be taking the valve off the top.
Tim S
08-11-2014 13:23:29
 Re: 4020 3pt doesn't work now after changing the seals an shaft in reply to bryang, 08-11-2014 13:14:34
It does matter where the load depth lever is when removing and installing the load shaft, it takes or puts on tension against the shaft,, and you need to be careful and "not" drive the shaft in with a hammer, it is possible to break a piece of the arm off and is a "major" job to repair,,like in removing the final drives and pulling the differential..and all kinds of bad happens with that...
