TractorLinks.com
Show Parts for Model:
4020 3pt doesn't work now after changing the seals an shaft
bryang
08-11-2014 09:59:12
Changed the seals an shaft on the yoke on the 4020 now the 3pt doesn't work. ? Ive done this on other tractors an all worked when I was done. Is their something I misses or did different im not catching!!? Thanks for any help!!
bryang
08-11-2014 14:14:45
 Re: 4020 3pt doesn't work now after changing the seals an shaft in reply to bryang, 08-11-2014 09:59:12
When taking off the valve block is their anything to watch for or keep in mind? Never took the one on the right off before.
Tim S
08-11-2014 14:53:52
 Re: 4020 3pt doesn't work now after changing the seals an shaft in reply to bryang, 08-11-2014 14:14:45
You will need a new gasket,, blow the area clean before you lift it and the hidden bolts should need a 9/16" socket,, but they rust bad down in there so you may need to use a 1/2"..
bryang
08-11-2014 15:24:31
 Re: 4020 3pt doesn't work now after changing the seals an shaft in reply to Tim S, 08-11-2014 14:53:52
I will have to get a gasket for it tomorrow. Cleaned it up good an all the bolts came out fine but it seams to be stuck not wanting to come off from the rear of the tractor. I cant find my book so im kinda relying on your guys for help!! Thanks for everything so far!!
Tim S
08-11-2014 15:53:06
 Re: 4020 3pt doesn't work now after changing the seals an shaft in reply to bryang, 08-11-2014 15:24:31
Make sure you got "all" the bolts out...i think there are 8...
Tx Jim
08-11-2014 16:18:17
 Re: 4020 3pt doesn't work now after changing the seals an sh in reply to Tim S, 08-11-2014 15:53:06
I checked the parts catalog & Tim is correct about eight(8) bolts holding RS valve housing on.
R26573 Gasket - GASKET,ROCKSHAFT VALVE HOUSING ADD 6.33 USD
This post was edited by Tx Jim at 16:18:40 08/11/14.
bryang
08-11-2014 16:51:00
 Re: 4020 3pt doesn't work now after changing the seals an sh in reply to Tx Jim, 08-11-2014 16:18:17
Yep I forgot one bolt got it out an off an yes in deed the little finger on top flipped over. ill get the gasket tomorrow if they have one probably not our local jd dealer has everything but what everyone needs!! THANKS for all the HELP guys I appreciate it!!! Thanks
bryang
08-11-2014 13:49:56
I never used a hammer on it or others so I hope im good on this one to!!
bryang
08-11-2014 13:14:34
Don't know if this matters but the 3pt raise an lower lever was in up/raise position.? I think when i have done others they were in lower. Would this cause a problem? Just a thought!? Looks like ill be taking the valve off the top.
Tim S
08-11-2014 13:23:29
 Re: 4020 3pt doesn't work now after changing the seals an shaft in reply to bryang, 08-11-2014 13:14:34
It does matter where the load depth lever is when removing and installing the load shaft, it takes or puts on tension against the shaft,, and you need to be careful and "not" drive the shaft in with a hammer, it is possible to break a piece of the arm off and is a "major" job to repair,,like in removing the final drives and pulling the differential..and all kinds of bad happens with that...
bryang
08-11-2014 12:51:46
Ok thanks Tim!
Tim S
08-11-2014 12:40:06
We just talked about this last week,, there is a strong chance that the cam follower got out of place up in the valve,, I don't know how they can get out like this but they do,, go back in the achieves and take a look at the pictures we posted,, if you can't find them we will show you again....
bryang
08-11-2014 12:00:52
No I didn't. Never done it before an they worked. What does it involve?
ET
08-11-2014 11:34:45
Did you follow the procedure in the service manuel to ajust the internal draft control linkage? It should be done whenever you have a load shaft out.
