2010 power steering issue
Phil Puestow
New User
My 2010 power steering just started to only turn to the right. You can't hold or steer the wheel to the left at all with the hydraulic pump engaged. Is there a pressure relief valve in the system or do I have to totally take the steering valve off the shaft. I was wondering if I could back flow with air pressure through the valve to loosen it or would this do more harm?
THE O-RINGS IN THE STEERING MOTOR AR MOST LIKELY WORN OUT. IT LOOSES TRAPPED OIL ON ONE SIDE THATS WHY YOU CANT TURN IT .Sorry abt. the caps
