JD 60 PTO clutch adjust oil pump seal leak
Dr. Bert
Decided to do a complete repair, but don't have the time right now, so will reassemble PTO clutch housing and fix things later. Would appreciate any tips on lining up the drive discs to go into the clutch drum. Thanks in advance. Bert
I have an old clutch hub to use,, but you can stick the PTO shaft in a vise, clutch up,, using a square line all the clutch disc up best that you can and using 2 pry bars "latch" the clutch in the engaged position to hold them in place then wiggle them into the hub...I know I said that so easy, but it's about the only way to do it...
To fix the oil pump leak, you need to pull the complete rock shaft housing off. Cause the pump is on the back side of it. And adjusting is different on early and late models, you need the ITT manual.
Tim: Thank you!! Your solution is so simple yet eluded me. I feel that I should be paying you a consulting fee for all the advice you have given me.
