TractorLinks.com
Show Parts for Model:
Tim, what do you think about this?
Richard in Bee
08-05-2014 12:37:47
Read this on another board. Is it true?
A side note about hyd oil levels in 20-30-40 series deere, you can overfill way over with no problems. We ran a 4020 on a hot workout and top notch deere tech said to just add five extra gallons of hyd oil to improve heat tolerance, same thing for a 30 series, had one that leaked and didn't have the option of fixing leak at that time, overfilled by five gallons and let it leak down to add, and added more. [i:5e0e3ae38a][/i:5e0e3ae38a]
Tech 7
08-05-2014 20:12:48
 Re: Tim, what do you think about this? in reply to Richard in Bee, 08-05-2014 12:37:47
I have not nearly the same amount of experience on the 20 series as Tim S has but I have certainly seen the same symptoms on 7xxx series tractors. If you have 4-5 extra gallons of oil in the rear end you will feel like the tractor on it ownn is pulling a railcar down the road.I have seen them get overfilled because the operator looked at the sight glass when the tractor was running or had just been shut off and taken a "false read" of the actual oil level.
Richard in Bee
08-06-2014 06:43:01
 Re: Tim, what do you think about this? in reply to Tech 7, 08-05-2014 20:12:48
Okay I'll take that as a "no".
Wonder what the guy who posted it was smoking.
Tim S
08-06-2014 07:35:47
 Re: Tim, what do you think about this? in reply to Richard in Bee, 08-06-2014 06:43:01
There are all kinds of different ideas on here and the discussion part is what irons them out...that and true life adventures...
D-
08-05-2014 14:58:36
Not true. As others stated will cause overheating. They were not meant to run under oil.
Tx Jim
08-05-2014 15:15:30
 Re: Tim, what do you think about this? in reply to D-, 08-05-2014 14:58:36
Full mark on dipstick was put there for reason. DON"T overfill by 5 gallons.
Tim S
08-05-2014 13:50:57
The oil seems to heat up more when over full....
DaveH IA
08-05-2014 13:44:16
I worked on a 4020 power shift years back that labored in 8th gear. after all the pressure checks and head scratching --- it was 5 gal over full
Mikein Ky
08-05-2014 18:04:45
 Re: Tim, what do you think about this? in reply to DaveH IA, 08-05-2014 13:44:16
I have a 4020 power shift that Tim is a little familiar with, and it was over heating the trans. oil. Also, not shifting like it should. I drained the oil down to the full mark and it was fixed. I had several John Deere experts tell me, Tim was one, you can't run it over full. They were right. I also have some IH tractors. You can run them over full.
