Ive got a 6200 4wd with cab that has some transmission
problems. It works fine in A &B range but when you put it in C &
D nothing. Cables are working up to the transmission but it feels
like something has came loose or broken because the shifter
doesn't have any tension just flops like it ant connected. I no the
cab tilts to the side but im wondering if itll tilt far enough for the
plate or piece where it goes in at is on the side the cab hinges
on. Or if anyone else has done this before and might no a
simpler way to get it out or off...??? Thanks if anyone might be
able to help!!!
able to help!!!
