I am trying to remove the governor and fan shaft assembly on a 1941 JD Model H. I have all bolts removed and using a putty knife was able to break the gasket material all the way around it. I cannot get this thing to budge. I have tried using a small screw driver and chisel to pry it up but I am afraid of cracking the casting. Any suggestions?
I have the service manual and it simply says to remove the cap screws then remove governor and fan assembly as one unit.
Thanks,
Thanks,
