Attn: buickanddeere
Dr. Bert
I have several questions concerning using wet clutch compatible oil in my 60 rather than replacing worn leaking seal between transmission and PTO. Email is open. Thank you---Bert
I think you're going to find that only gear oil is compatable with the trans. Even if you went with something else it will be pumped into the clutch housing overfilling it.
Exactly,, the bushing and shaft wears and a seal will no longer work till all is renewed...
