Deere 6405 Hydraulic/Transmission Low Pressure
deere6405
New User
My 02 Deere 6405 had a light to show up on the dash today for the hydraulic/transmission low pressure. The tractor will not go into gear and move at all but the hydraulics still work; however, the loader is a bit jerky when you raise it. I thought it may be the pressure sensor but I don't know why that would make it not move. Any ideas what the problem might be and where it would be located.
Shane
(quoted from post at 21:44:29 07/31/14) My 02 Deere 6405 had a light to show up on the dash today for the hydraulic/transmission low pressure. The tractor will not go into gear and move at all but the hydraulics still work; however, the loader is a bit jerky when you raise it. I thought it may be the pressure sensor but I don't know why that would make it not move. Any ideas what the problem might be and where it would be located.
Shane
Syncro-Plus or Power -Reverser?
Hours, history? last transmission oil and filter change?
Unusual sounds ? Oil colour and smell? Oil level ?
Do you have oil pressure test gauges? Did you try it with the loader supply lines disconnected ?
TRANSMISSION OIL FILTER
Cart key PART NO. PART NAME QTY SERIAL NO. 6405 REMARKS
1 AL156625 Oil Filter 1 X (SUB FOR AL77061)
Syncro-Plus Transmission
Has 3065 Hrs and Filters changed at 3000
All Fluids are full and seem normal and sounds normal
I used the tractor yesterday to pull a scrape box and everything worked like normal. I got in it this morning and the light came on and wouldn't move. I don't have any pressure gauges
(quoted from post at 04:08:18 08/01/14)
I agree on checking pressure with a gauge. It could be as simple as a faulty sensor but I like to diagnose rather than just swap parts.
I bought a gauge this morning. Where on the transmission should I put the gauge and what pressure would be normal.
(quoted from post at 11:29:51 08/01/14)
There probably isn't any info in the operator's manual. The good news is that the nice folks at 1-800-522-7448 have service manuals on CD and hard copy.
Locations , procedure and specs should be there. The price of a manual and gauge could save you $ thousands incase your mechanic is a parts replacer instead of a trouble shooter.
