fuzzeykatz
New User
I have a 1961 JD 4010 that my dad purchased in 2003. It still has the 24 volt system. My dad and brother have passed away recently and I'm trying to figure things out with this tractor. Using it for cutting and baling hay. Started great after sitting over winter and for first few times using it. Then it wouldn't start, replaced one of the batteries (left side) that tested at 10 with volt meter, right side battery tested fine. Now it starts but the generator indicator light does not come on when the key is first turned like it is supposed to. Once started it comes on and once the rpms are increased it goes off as it should. The operators manual says to determine cause of light not coming on when key is turned but offers no help. What and how do I start the investigation. Any help would be greatly appreciated. Fuzzeykatz
