37 A fan stoped running
Is cole
New User
I was driving my 37 A yesterday when I heard a sound for
about 30seconds then the noise went away the fan stoped
turning but the tractor still runs fine I'm not sure what the first
move to make is I really don't want to have to take the
governor off any help would be great thanks
Time to remove the Gov. and Fanshaft. Whatever happened, those 2 things will need to be removed. The fan won't come out past the radiator.
While you have the fan shaft off it would be a good time to put a friction disc fan on it if it ain't already been changed. My 37 A I lost my fan and hit the radiator . A bearing might of went out causing your gears not to mesh . You won't know until you pull the fan shaft to see what's wrong .
