3020 LP Parts?
JD dealer says the connections from the tank to the long shutoff valves are no longer available. Sources? Ideas?
JD dealer also says the fuel tank valve which also connects to a dash fuel guage is also no longer available. Sources??? Ideas?
Thanks, kelly
Parts key 6
The part R27184 is no longer available. Contact your local John Deere dealer for other options.
I don't understand which part you need associated with fuel gauge.
this site shows one listed for 90 dollars and some odd change. I just put an aftermarket one on my 2510 and it works great.
If you are referring to the two valves that the long rods connect to they are marked/stamped with a number like BR7130 and are available at any propane supplier along with the sender for the guage. chris
Thanks to all for the replies/help.
Tx Jim, I probably need the entire part number 20 on the picture you sent. Thanks for that--it really helps! (I should have said: "guage" rather than: "valve".)
