4640 transmission issue
Dr Dawgs
New User
Do not have forward 1-4....trying to rule out every possibility before splitting the tractor in half....Thanks Stan
I"m guessing it"s a power shift and also thinking it"s a C3 clutch failure, here is a chart to help with your thoughts.
(quoted from post at 10:18:24 07/23/14) I"m guessing it"s a power shift and also thinking it"s a C3 clutch failure, here is a chart to help with your thoughts.
m with you c3....I will recheck pressures and if they are ok....I will prob have to split tractor and rebuild???
(quoted from post at 12:36:39 07/23/14)
I guess if forward 7 is involved...then definitely C3 is involved.....Do you think if I choose not to repair it will cause additional problems?
Yes it could in the long term,,you could finish the immediate work and tear it down on your terms..
