Anonymous-0
My old 620 has been doing great until this morning, I was
clipping pasture when it got to heavy pull and engine started
to slow down it began to miss ck every thing I know any idea
what is wrong it's a LPG
your out of fuil dont trust gauge ,tank line off turn fuil on and then key if it has plenty of fuil it will have lots of presure not just some pressure, also make sure there are no flames or fire at this time you could blow up.I always take a screew drive and tap the place were you fill it up tap lightly if the center button stays in your out of fuil.BE CAREFULL
All LPG's I have been around come to a quick stop when they run out of fuel. Check the oil bath for proper oil level.
I ck the strainer on the elect shutoff hat sum seettlement. And rust thanks I just put on just while back new
lp tractors can be out of fuil but on a very hot day they will still start but will not take trottle. you see lp builds up its on pressure even in an empty tank?????? I have more than one of them and it happens alot.
