DETENT on a 3010 Hyd. Lever
lenray
I just use this tractor to operate a 3 pt. sickle mower and have a hyd. cylinder to raise and lower the bar.
I don't like how the DETENT works.....Can it be eliminated????? I want it to work SMOOTH...................THANK YOU
You could change the control rod in the scv lever to the other hole for "float position. This requires removing cowling in-between dash & hood to access rod/lever.
The detent can be adjusted to be softer by backing out the adjusting screw on the front side of the valve.
