David from Kansas
I have two JD parts: R42895 and R42896 (casting numbers). Need help identifying them and what model(s) they fit. JD parts says one is no longer available and one gives a sub number and calls it a fender support???
Thanks for any help you may be able to provide.
First search(R42896) showed it to be a cushion for the floor mat of the cab on a 5020, but then found it to be a fender mount on a 5020 rowcrop. chris
Thanks, Chris.
The search I did showed one of them as no longer available and the other as a fender mount. Wish I could puts some pics on here as that may help. The one number (fender mount) shows a sub number with a price of $6xx.xx. I have s 5020 standard but it will not have the same mounts as a row crop.
