Working on my brother in laws 70 tractor clutch and have a
question about the clutch disks. Do the floating clutch disks
ride on the adjusting bolts or the pins? Previous owner had
them riding on the adjusting bolts. The reason for working on
it is because it does not want to disengage after you pull back
on the clutch handle. Would worn clutch dogs be part of the
problem? I did find the outer clutch disk stuck to the adjusting
plate.
plate.
