roosamaster
russdog
I asked on an earlier post about the metering valve not working.I took the top off the injector pump and started the motor up and the governor did not move. I manually worked the metering valve and it did work. I went thru the pump awhile back and it went together pretty good,or so I thought. I was very careful putting the governor weights and other parts in. Could they have come loose putting the assembly back in the body? I tied the throttle lever back when I got it together. Thanks,Ken
