Hello,
Correct me if I am wrong but shouldn"t there be only engine oil in the gear reduction side of the tractor on a John Deere A? Tractor was just serviced at the local school for a project and I noticed a rattle in the belt pulley clutch area (broken ear on a clutch operating bolt) so I pulled the clutch fork assembly and noticed a pinkish oil on the gear teeth. I checked the engine oil and it is engine oil but when you would stop the engine and the gear oil would start dripping off the teeth it will drain off into the engine crankcase via the one inch port.
What would cause this to happen?
Thanks,
Thanks,
