JD Research: Code ab2234
This message is message to A GURU or anyone that can provide information on John Deere Styled A Special Equipment codes.
I had Two Cylinder Club do research on my AW based on serial # 632211. Special equipment is listed as: aa4073 "for use with front wheel load equalizer for "A" (#58400).
Does anyone have any knowledge of what these codes mean ... or a source that can used as a reference?
Chris, the codes mean whatever is printed after them on the research document. Now that description you gave about the "load equalizer"/aa4073 sure is open for interpretation. My guess would be that they might mean "roll-o-matic" and that it might be heavy duty front wheels. Almost all "special equipment codes" are simply the wheel equipment codes.
I have very few codes documented on A's, because there is no production register available for them. Any codes I accumulate come from folks like you. I don't know what ab2234 is, but it should be listed on the document after the number and is likely the rear wheel equipment. If you have a way to post the document, or type it verbatim, I'll tell you whatever else there is to tell, if I can add anything.
Another option is to contact Two-Cylinder and ask them to elaborate on the aa4073 code, if they can. Jack Cherry could probably provide some further insight on that one.
Not sure I've helped you much.
Anyone reading this that has research documents on their A's (or other Waterloo Letter Series) I would be glad for whatever equipment codes/descriptions (and any of the other info) you might be willing to share. E-mail is always open.
