Schwartz for 3010
2510Paul
I am putting a used Schwartz front end on a 3010 JD. Most of you know the 3010 has a 4 bolt mount to the steering motor up front. I notice in the catalog the correct steering arm on a Schwartz front end has a four bolt matching mount. The used one I have only has an arm with holes for two bolts. Question, has anyone seen any adverse affects like loosing the two bolts in this arrangement?
The correct arm is $80 at A&I so I just soon use what I have if I can trust it. Thanks. Paul
I don't know, but I do know that those four bolts are the only thing holding the front end on with a narrow front. So maybe two bolts will steer it just fine.
Are you sure yours is a Schwartz? There were others. A&I also has Speeco parts.
