730 hydraulics
The rockshaft hunts under load - I suspect position control is not
working - will this be in the control valve - can I get at this by
taking the top cover beneath the seat off - or will I have to remove
the entire rockshaft housing?
Does the rockshaft hold a hold for a period of time when the tractor is shut down?
TYPICALLY the first thing to look for when a hitch system "hunts" is a leaky cylinder seal (or other leak in the pressure plumbing to the cylinder).
