JD 100 lawn tractor problem
Tractor starts miss firing after about an hours use. Will run somewhat with choke partially engaged. Turn it off and let it sit for awhile and will run again for a limited time before it does it again. Unit has about 300 hours on it. Any ideas what the problem is? Thanks.
like roger said - could be the fuel cap vent -check for any fuel blockage in the fuel system -- misfire -- does it lose power? after an hours use could also be coil breaking down from heat -seen them get to the point where there is no spark and it stops - after stopping for a while will restart
