Anyone having problems with the seals on the 3pt lower links? Changed mine last fall complete with new shaft. The previous ones were in there for 8 years. The new ones started to leak last month from both sides at once almost, leak really good. Got new seals from JD and went to install them. They seem to be too small for the shaft. When I tried to fit them on the shaft, they would barely go over the tapered part at the end. Any more and they would distort the seal. When I took the old seals out, I noticed the rubber came out in two pieces. Never had problems before sliding an oil seal on a shaft. Any thoughts?....Ron
