Ok, I"ve got a "48 B. I was shredding grass and met a mound of dirt. The shear pin didn"t shear, and I didn"t get the clutch pulled fast enough. I now have a clunk in 1, 2, 4, and reverse (right side of shifter), but not in 3,5, and 6 (left side of shifter). I"ve never been inside a transmission so I need to ask the brain trust, "Do you think I knocked a cog off a gear?" and "If I did, which gear do you think I need to replace?" I have the service manual, and by looking at that, I"m guessing that I"ve messed up the countershaft idler gear. What do you think?
I had someone suggest that it may be a bearing. I pulled the 3-bolt cover behind the flywheel, and that bearing looks OK.
