I have a 1994 John Deere 318 with an Onan engine. The tractor has begun to start hard and I noticed it was initially running a little rough before eventually running smooth. This problem has continued to get worse. The past few times I have used it, it takes longer and longer to smooth out. I have run a couple tanks of gas through it since this problem has started and have changed the plugs. I have blown out the air filter and it looks fine but I do plan to replace this and the fuel filter. I doubt this will solve the problem, as the motor gets hot it seems to run better. Any other possible solutions would be appreciated.
Thanks, Bill
Thanks, Bill
