Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 4430 2 speed and steering problems! Help!
Tx Jim
07-09-2014 06:20:49
I agree with MikeJM on check the easiest things 1st. Here's a parts photo of the clutch operating valve that MikeJM referred to. To check stand-by just plug a 5000# gauge into rear breakaway coupler and move control lever.
johnyquest69
07-10-2014 05:07:25
 Re: 4430 2 speed and steering problems! Help! in reply to Tx Jim, 07-09-2014 06:20:49
I plugged gauge into scv and got around 2100# pressure. On 1 of the 4 ports on the 2 scv's would hold that. Not sure how they are supposed to act. I loosened filter housing and turned tracor over and had lots of oil come out. i took hose loose that goes to front pump and had good oil flow also. I went to put tractor back under shed and 2 speed was working. Still no power steering.
buickanddeere
07-10-2014 06:55:08
 Re: 4430 2 speed and steering problems! Help! in reply to johnyquest69, 07-10-2014 05:07:25
Time to dial that stroke control valve to 2300psi
Tx Jim
07-10-2014 09:01:57
 Re: 4430 2 speed and steering problems! Help! in reply to buickanddeere, 07-10-2014 06:55:08
johnyquest69
Although dialing up stand-by pressure to 2250-2350 psi may help cycle time it won't help this tractors hyd problem. Gauge leaking off on 1 breakaway coupler indicates a poppet valve in scv isn't seating/sealing.
johnyquest69
07-10-2014 10:40:48
 Re: 4430 2 speed and steering problems! Help! in reply to Tx Jim, 07-10-2014 09:01:57
Jim, My main problem right now is my steering. Do you think filters in the "brick" could be the problem?
Tx Jim
07-10-2014 13:36:43
 Re: 4430 2 speed and steering problems! Help! in reply to johnyquest69, 07-10-2014 10:40:48
If itr was my tractor I'd be cleaning the filter in steering valve
johnyquest69
07-16-2014 05:38:55
 Re: 4430 2 speed and steering problems! Help! in reply to Tx Jim, 07-10-2014 13:36:43
I just wanted to tell everyone thanks for the advice. I don't know what happened but everything has returned to normal. Stuck valve maybe? Thanks again!
buickanddeere
07-10-2014 11:34:55
As txjim pointed out. If the scv is passing oil from the HP side back to the pump when no hydraulic load is in operation. That is a serious failure that can not be bandaged around .
johnyquest69
07-10-2014 11:48:27
 Re: 4430 2 speed and steering problems! Help! in reply to buickanddeere, 07-10-2014 11:34:55
i'm not sure about testing scv's. On right hand scv I could plug into right side port and move lever. Pressure would go up to around 2100 and hold. On left port of right side scv I could mover lever opposite direction and it would go to 2100 and then fall once lever went back to neutral position. Same way on left hand scv but pressure slowly leaked down on right port.
Copyright © 1997-2015 Yesterday's Tractor Co.
