Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: JD 630 Killed Itself? Kinda Long Post
BushogPapa
07-08-2014 19:32:11
IF that is what happened...when you get ready to Re-install that (either) Bearing Quil, put a short piece of Threaded Brass Tube in place in the existing Threads for the oil feed, extending enough to prevent that "O-Ring" (that JD calls a Gasket) from migrating into and blocking the passage.. The size is about what you will find in old living room Lamps, with the chord running through, to the fixture and works perfectly..Correct thread and all.. New Main Bearings are "Under-size and can be Brass or Aluminium.. Clearances differ with these, but NO less than .005"
Ron.
Copyright © 1997-2015 Yesterday's Tractor Co.
