You posted about a serial number a while back. Since then I have worked with some steel tags.
They are thinner than the aluminum tags. I told you I hadn't seen numbers on the back of those aluminum tags. Sometimes the numbers are visable on the back of the steel tags sometimes not. I have developed a process to learn the numbers on the steel tags if you want to send yours.
I had guessed wrong on several of my Hs. One had steel wheels on the front but they had been added. It was older than I thought.
