clutch make a slapping sound when disengaged.
Your Manual will tell you what end-to-end clearance should be..
A Dial-Indicater will be handy..
Should not exceed .010"and .010" would be over the limit..
Ron.
Time to take the manual and disassemble the pulley right down to the bare crankshaft and pull the driver off.
Clean, inspect and replace worn or broken components. Adjust as per manual.
Operating a tractor that won't stop when the clutch lever is pulled can ruin property and main or kill persons.
The bearing is often ruined by operators who don't operate the tractor as per the manual.
