TractorLinks.com
Show Parts for Model:
Re: John Deere M running on 1 cyliner
Plant Doc
07-06-2014 15:16:30
Jay: You said you overhauled this M? Has it ever fired on both cylinders after the overhaul? If not I would be looking at the Distributor timing. I suggest you bring up #1 cylinder on compression and look at where the distributor rotor is pointing. Then do the same with #2 cylinder and check the position of the rotor. My guess is, if this M has never fired on both cylinders after the overhaul that either the oil pump is off a tooth or two or the distributor needs to be turned about 45 degrees in the direction the rotor turns. If I misunderstood and this M has fired both cylinders after the overhaul, then disregard all of the above.
Jay Chrisman
07-06-2014 16:10:11
 Re: John Deere M running on 1 cyliner in reply to Plant Doc, 07-06-2014 15:16:30
No never fired on 2
nlastovi
07-06-2014 21:07:29
 Re: John Deere M running on 1 cyliner in reply to Jay Chrisman, 07-06-2014 16:10:11
This may have been answered, but I didn't see it in a quick scan. Is there *spark* at #2? Pull the plug, put in on the wire and hold it to ground. It ought to show nice spark (at least as big and bright as cylinder #1 does).
