46 A clutch
When the clutch is engaged or disengaged? Motor running, etc. Please be more specific. A distinct pop noise should be heard when disengaging but when locking over it is quiet.
With engine off & clutch engaged, try to move your pulley by hand. If you can wiggle the pulley back & forth slightly without moving the crankshaft you have a loose clutch driver & ruining your splines on crank. Hopefully, you don't have this problem but if you changed your facings you had the driver off so you better double check to see if you tightened the driver on.
