Yesterday's Tractor Co. Compare our Prices For Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
50 radiator core replacement
Fudd
07-06-2014 12:40:04
209.180.243.98
I need to replace the radiator core on my 50. Instead of removing the steering shaft and worm gear, can I just unbolt the shaft assembly from the pedistal? The 4 bolts on the side. Where is a good place to get a core? Thanks.
[Reply]   [No Email]
andy r
07-07-2014 08:25:03
75.91.149.15
 Re: 50 radiator core replacement in reply to Fudd, 07-06-2014 12:40:04
Did my John Deere 50 a couple of years ago. I personally think that it is too complicated to replace the core without being able to turn it for access. Pulling the steering shaft back so the radiator will come out easier isn't that big of a task. I think I sprayed the bolts on the bottom of the radiator and tried to get penetrant to loosen the bond. They both came out. Can't remember if I applied any heat. I bought an after market radiator and it fit fine. Some say the aftermarket ones have problems. Might have been one from A & I or Iowa Equipment near the Tipton, Iowa exit off of I-80. Had at least one bolt break off in the radiator casting. Had to drill it out and retap. I believe I took the heat sensor for the radiator shutters out too and capped the hole. Just too many problems with my radiator to do it in the tractor.
[Reply]  [No Email]
BushogPapa
07-06-2014 21:12:15
173.88.50.145
Power Steering or Not..?
[Reply]  [No Email]
Fudd
07-06-2014 21:36:20
63.228.77.57
 Re: 50 radiator core replacement in reply to BushogPapa, 07-06-2014 21:12:15
No power steering.
[Reply]  [No Email]
jeo46
07-06-2014 18:38:20
184.20.40.156
Best way is to remove the radiator. Spray penetrating oil on them, heat bolt heads with a torch (do not melt them) to break the rust lose, turn them a little and spray penetrating oil on each one(heat them again if necessary). Turn them back and forth until they will turn out without twisting off. Clean threads with a tap carefully so it goes together freely.
I have done many this way. Watch word-patience!!!!!!!
[Reply]  [No Email]
Fudd
07-06-2014 16:31:08
63.228.77.57
Another question. Do I have to remove the whole radiator or can I remove the top, then the core and leave the bottom in place.
[Reply]  [No Email]
BushogPapa
07-06-2014 21:10:59
173.88.50.145
 Re: 50 radiator core replacement in reply to Fudd, 07-06-2014 16:31:08
Take the whole think out and do it right the 1st time... There is nothing hard about taking the steering shaft out..
Ron.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
