Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: John Deere M running on 1 cyliner
07-06-2014 11:50:06
Try a new spark plug-I had a new one fail to fire. Could hold wire away from seating in distributor cap a little(just enough to get a hotter park) and see if it plug starts firing. Look at picture of distributor in owners manual and make sure it is in the right position. Your valves might not be opening (push rod off or valve sticking and/or not seating properly.
You have to run the traps to see if you can figure out problem. I installed oil pump 180 deg out and it just backfired-would not run. Had to pull pan and re install oil pump correctly.
