4020 trans pump
Anonymous-0
Is there any place to get a complete trans pump for a side console 4020. Deere only sells them with housing and gears sold separate. I know only a and I sells the housing.
I got 2 from A&I last week,, I'll post the part # tomorrow, it was half price of Deere and work well
A&I 4020 trans pump
Yes Jim that's the one,, Half price of Deere and just as good...I put 2 of them in 4000's last week...
You can usually add "A-" to a Deere part number to see if that part number is serviced by A&I. Also, you can go to jdparts.com and price the A&I item by doing the same thing. Mike
To add to what Mike said you some times need to enter the older Deere part number with the A- in front of it..
I'll add to what Mike & Tim stated that sometimes A&I part number is totally different from JD part number. AR41949 doesn't show up in PC for 4020 < SN 200.999 but trans pump is PN AR32995 OIL PUMP. AR41949 is listed in PC for 4020 > SN 201,000 but is housing(parts key 11) with pin only no gears according to parts description. A-AR41949 is $237.57 from local JD dealer instead of $260.75 from A&I.
