My "39 H makes a terrible squealing noise at the governor. I took the oil feed line off where it enters the flywheel side of the governor and there is no flow. If I unhook it at the pulley side, oil just dribbles out without enough force to move it through the tube. If I use an oil can to inject oil into the hole the noise goes away, so hopefully the bearing isn"t shot, or the gears don"t need the backlash set as so many do. Oil pressure gauge reads normal. Haven"t yet put a gauge on to see the actual pressure number. Is there a way to backflush this supply or can I increase oil pump pressure?
