I have recently been rebuilding one of the lift cylinders of my Deere 148 loader, and after reviewing various messages that I've found on the internet in my search, I thought I'd post something to maybe help someone else when they tackle the rebuild.
When taking the cylinder apart, I found several things that were a PIA. Even though there were no holes, I used snap-ring pliers to spread the retaining ring enough to get the ring out of the groove, then a screwdriver, going around the ring to complete the task. Then after the guide was pushed back into the cylinder to access the inner retaining ring, I used a screwdriver to unseat the ring deeper into the cylinder and then used a hook to pull it out of the cylinder. I couldn't get any purchase on the ring with the hook when it was seated, but it came out easily after being unseated.
I screwed up the seals when reinserting the piston into the cylinder because I'd overtightened the end bolt of the piston, which causes the seal to spread out. You want to tightened it enough to get a good seal, but you'll never get the piston back in without screwing up the seals if it's over-tightened. I used gentle pressure with a hydraulic floor jack, and some wiggling of the piston, to push the piston into the cylinder.
Hope this helps someone.
