r main oil line removal on JD 60
I just took one off yesterday but I had the block off tractor, I think it was a 11/16th wrench or a 5/8 but if you go in from the top you will hsave to feel for it, I took all lines off and gonna take filter head out and oil pump and sell all of it if I can good luck, takes a long skinny arm.
the line doesn't have to come off to remove the main bearing.If your removing the line for other purposes it can be done , not much room.
