hydraulic lines
Go to jdparts.com and look at the parts books for that model as there are a couple of options. One is a complete selective control valve and another is tapping pressure from the rockshaft to operate a one way cylinder like on a haybine.
Valves bolted to RH axle housing. You would need to pick up used from salvage yard and would still be pricey.
Any neighbors with utility tractors you could look at?
