con rod shims
Is there any problem with making shims out of coke cans?
I have 3 shims and can't get the right clearance with any combo of the three between the 2 steel ones. Figured I could just cut some out of pop cans.
Any thoughts?
Easiest way to do it?
Todd,
I assume you are adjusting the rods on a "D". Remember how old this engine is & how many experienced (?) have worked on it. Are you using a 0--1" micrometer to measure your shims? This will solve some of your problems. The shim pack should have enough laminating shims,002-.003 left in it to fit up a old worn crankshaft.I like to start with a even amount of shims on both sides of the rod, this keeps the cap & rod surface square. Forget plastigage. Make sure you torque back the same pounds each time you try. Make sure before you tighten your cap you take a hammer & tap the rod & cap over to the side of the journal to properly align the cap & rod. The side clearance is often overlooked when dealing with babbitt rods. Each time you remove a shim & retorque,lubricate 30 wt oil, roll the engine over a complete revolution, because the crankshaft is out of round .Those are large bearings & the oiling system pumps a volume of oil.at low pressure. Send me your phone number & when to call I can help you. Earl
there are tapered brass shims made specificaly for
rod bearing shimming, cant remember the company
name but try google search for tapered shims
I agree aluminum is to soft. I have cut rod shims out of transmission bearing quill shims.
I talked to my local antique tractor guy and think I got it handled but all the help I can get is appreciated.
do you have an email I can send my number to?
