36 in to 38 in rim
Check out Gemplers.
They should have an online catalog. I remember seeing something like that in their catalog.
Deere did have a factory step-up rim that would fit on your casting (odds are it is a B3600R casting that would have originally been on a 520/530). If you look up a 38" wheel for a 2630/2640 you will find a 38" rim that goes on the B3601R casting that was offered on those tractors. This casting is the offset version of the B3600R and was also offered on the 520/530. This being said, by the time you buy a pair of these you could have bought a pair of common, used F1500R wheel castings and rims for the same or less money. Mike
Deere used step-up rims on some utility tractors. Maybe 2840?
I might have a set for 18.4x38. Too big for your tractor.
You might try salvage yard for complete cast and rims like was already suggested.
I have a set of 12x38 step up double bevel wheels. Stamped Firestone, stenciled John Deere Syracuse NY. Not sure if they are 36" or 34" at bevel, need to measure them to be sure. Bought them thinking I"d weld in a 38" center, didn"t notice the step up in the center till I had them home. If they"re what you"re looking for I could part with them. One is in excellent condition, the other has some rust right at the valve stem hole, but is still in very good condition.
Didn't they also make long rim clamps for this? It seems I've seen tractors with 38" rims with an inch or so of gap all the way around. I thought maybe they had 36" centers with longer clamps.
