2240 buying a used rockshaft housing complete
Can someone answer a question for me. Many rockshaft housings will fit my 2240 they look identical but casting numbers don't match. what gives?
How do i tell which ones will work. I'm trying to purchase housing, arms, cylinder, etc so I can just swap it.
my casting numbers are
L34402
L34403
L34404
Of those three numbers one should have a mark beside it. That would be the number for your housing.
(quoted from post at 22:46:03 06/17/14) Of those three numbers one should have a mark beside it. That would be the number for your housing.
Didn't see any marks but, might be covered by dirt.
Do I need an exact match in order for it to work? So many of them look identical.
I would want the numbers to match cause I've been bit by one on a 2950 that wasn't correct. Pulled that rockshaft so many times the owner of the dealership started calling me rockshaft. One little hole under the valve that wasn't there but it took finding out the casting number was wrong and laying a correct casting beside it to find the problem. Dealership lost a bunch of money on that one.
(quoted from post at 07:08:45 06/18/14)
It's odd that those casting numbers aren't listed in the parts catalog under parts descriptions. What's your tractors serial number/
Never wrote the serial down. won't be back where the tractor is till Saturday. It is the later model 2240 350,000 and up.
(quoted from post at 07:37:43 06/18/14)
350,000 up AL31424 HOUSING 1 (ALSO ORDER 15H638) (SUB AL71101, T21630, T21631 AND 15H638) shows to fit all the following tractors.
1763 - 2040 Utility Tractor (350000- ) - 16May11
1764 - 2240 (350000- ) Tractor - 16May11
4143 - 1830, 2030, 2130 Tractors - 12May11 ( FR DE IT ES SV )
4152 - 1020, 1120 Tractors - 12May11 ( FR DE IT ES SV )
4154 - 830, 930 Tractors (European Edition) - 12May11 ( FR DE IT ES SV )
4155 - 1030, 1130, 1630 Tractors - 12May11 ( FR DE IT ES SV )
4163 - 820, 920 Tractors - 12May11 ( FR DE IT ES SV )
4164 - 2020, 2120 Tractors (European Edition) - 12May11 ( FR DE IT ES SV )
4172 - 940, 1040, 1140 Tractors (European Edition) - 11Jun14 ( FR DE IT ES SV )
4173 - 1640, 1840, 2040 Tractors ( -429999) European Edition - 11Jun14 ( FR DE IT ES SV )
4174 - 2040S, 2140 Tractors ( -429999) European Edition - 11Jun14 ( FR DE IT ES SV )
4182 - 2150 and 2255 Tractors (North American Edition) - 11Jun14
4184 - 1640, 2040, 2040S Tractors (430000- ) - 11Jun14 ( FR DE IT ES SV )
4185 - 2140 Tractor (430000- ) - 11Jun14 ( FR DE IT ES SV )
4187 - 2350 and 2550 Tractors (North American Edition) - 11Jun14
4188 - 2750 Tractor (North American Edition) - 11Jun14
4190 - 840 Tractor (s.n. -599999) European Edition - 11Jun14 ( FR DE IT ES SV )
4210 - 2650, 2650N, 2850 Tractors (Synchro-Transmission)(European Edition) - 18May14 ( FR DE IT ES SV )
4211 - 2250, 2450 Tractors (Synchro-Transmission)(European Edition) - 29May14 ( FR DE IT ES SV )
4212 - 1550, 1750, 1850, 1850N Tractors (European Edition) - 29May14 ( FR DE IT ES SV )
4213 - 1350 Tractor (European Edition) - 18May14 ( FR DE IT ES SV )
4215 - 2755 (GPT) and 2855N Tractors (North American Edition) - 18May14
4216 - 2355 and 2555 General Purpose Tractors (North American Edition) - 29May14
4217 - 2155 and 2355N Tractors (North American Edition) - 18May14
4223 - 2250, 2450, 2650 Tractors (Collar Shift Transmission) (European Edition) - 29May14 ( FR DE IT ES SV )
4224 - 1950, 1950N Tractors (European Editon) - 18May14 ( FR DE IT ES SV )
5034 - TRACTORS BUILT IN SPAIN 1030OU,1630OU,2030OU (50000- ) - 30Aug01 ( FR DE IT ES SV )
5035 - TRACTORS BUILT IN SPAIN 1035EF,1635EF,2035EF (50000- ) - 12Apr04 ( FR DE IT ES SV )
5037 - TRACTORS BUILT IN SPAIN 2030,2130 (50000-) - 12Apr04 ( FR DE IT ES SV )
5040 - TRACTORS BUILT IN SPAIN 2035,2135 (50000-) - 12Apr04 ( FR DE IT ES SV )
5050 - TRACTORS BUILT IN SPAIN 940V,1040V,1140V - 12Apr04 ( FR DE IT ES SV )
5051 - TRACTORS BUILT IN SPAIN 1140F,1640F,2040F - 30Aug01 ( FR DE IT ES SV )
5052 - TRACTORS BUILT IN SPAIN 940,1040,1140 - 30Aug01 ( FR DE IT ES SV )
5053 - TRACTORS BUILT IN SPAIN 1640,2040 - 30Aug01 ( FR DE IT ES SV )
5054 - TRACTORS BUILT IN SPAIN 2040S,2140 - 30Aug01 ( FR DE IT ES SV )
5056 - TRACTORS BUILT IN SPAIN 1840,1840F - 30Aug01 ( FR DE IT ES SV )
5057 - TRACTORS BUILT IN SPAIN 1750V,1850V - 30Aug01 ( FR DE IT ES SV )
5060 - TRACTORS BUILT IN SPAIN 1850,1950 - 30Aug01 ( FR DE IT ES SV )
5061 - TRACTORS BUILT IN SPAIN 2450,2650,2850 - 30Aug01 ( FR DE IT ES SV )
5062 - TRACTORS BUILT IN SPAIN 1850F,1950F - 30Aug01 ( FR DE IT ES SV )
5064 - TRACTORS BUILT IN SPAIN 2450F,2650F - 30Aug01 ( FR DE IT ES SV )
5065 - TRACTORS BUILT IN SPAIN 2250,2250F - 30Aug01 ( FR DE IT ES SV )
6048 - 2755 Tractor (with Turbo) - 10Jul08
7055 - TRACTORS 2141,2541,2941 - 30Aug01 ( FR DE IT ES SV )
7058 - TRACTORS 1641,1641F - 30Aug01 ( FR DE IT ES SV )
7063 - TRACTORS 2251,2251N,2351 - 30Aug01 ( FR DE IT ES SV )
7064 - TRACTOR 2651,2951 - 30Aug01 ( FR DE IT ES SV )
(quoted from post at 09:07:33 06/18/14)
Thank you Sir. That really helps. i knew there had to be a bunch of different ones that would work. i have no idea how the owner managed to do it but, the cylinder in the rockshaft is cracked. Tractor was bought at an auction. It's in good shape otherwise. i just need to get this problem fixed.
