john deere 60 power stearing
need to know where to take my john deere 60 power stearing pump to get fixed, see tractors for sale on here with rebuilt pumps but cant seem to find anyone that works on them please help ! mine works some what but is slow and dosent help when it gets warmed up also the flow is ajusted all the way,
Pump is easy enough to RESEAL, but rebuilding it to "new" specs" ain"t gonna happen because the housings wear and even with new gears the tolerances between the gears and the housing won"t be as close as new.
I would not condemn the pump without being able to check it"s pressure and flow, and there are several other things that could cause weak steering, as well. (Valve or van motor issues).
Oh, and BTW, are you using the recommended John Deere 2-cylinder power steering oil?
Wonder if you can still buy the center section of the pump housing ? I have replaced several of those years past due to wear.
I forget what I paid for the last ones they were never cheap. LOL.
Just dang glad I could still get them. Only way to get the pump working good. The ones I had really had a lot of wear ! No mics needed. You could use a ruler.
