I have a late 40U, and need to remove the drawbar frame; part #
AM2405, called "Load link mount assembly" in the PC.
Each final drive housing has a dowel insert (M1568T) which goes
part way through the final drive casting and AM2405. So, even
after the bolts holding AM2405 to the final drive castings are
removed, the frame will not drop down due to the dowels. Yes,
they are rusted in place in the final drives, but AM2405 is loose
on the dowels.
How to get them out - so I can remove AM2405?
My best idea so far is to loosen the final drive from the
transmission case a 1/4" or so - move it outward - so AM2405
can clear the dowels.
Any better idea?
on the dowels.
Any better idea?
