5020 tight on left wheel side
Barring bearing failure, it"s likely a brake that"s not releasing, commonly due to a sticky brake valve.
Does the LH brake pedal "feel" any different than the right one?
You can probably temporarily release the brake by loosening the LH brake bleed screw a turn. (Do NOT remove it.)
Yes all good answers,, the pedal valve is leaking past,, some times you can bounce your foot on it a few times and it will purge clean,,it's not a bad job to repair I can walk you through it easy when your ready..I would replace both valves while your in there, and the boots if they are bad, here is the #'s 1- AR31946..Kit $53.96....2- AR52497..Valves @$60.11 each
I'm going to have to do this also on my 5020, not because of brake hanging up, but because of a big oil leak. I've ordered the kit and boots, but not the valves. will I be ok without the valves or is that needed
